USR Router Firmware update - FTP won't work....
Threaded View
These are the errors I see and user sees
"(not logged in) (24.70.193.229) > connected to ip : 0.0.0.0" Is what
I see
"Can't connect to remote server. Socket error = #10061." what they
see.
I am using a USR 8054 Wireless G. I did an firmware update to version
1.64 and now its broked :(
Here are my settings.  http://members.shaw.ca/katana-1100 /
Thanx
Re: USR Router Firmware update - FTP won't work....
>I see
>see.
Did you reset everything to defaults after the firmware update?
Nice documentation job.  I'm not familiar with the SMC 8054, but I
have run into similar problems.  Some NAT routers will NOT allow input
port redirection to DHCP assigned IP addresses.  I suggest you change
your client computahs IP address from 192.168.123.100 to a static IP
address that's outside the DHCP address range.
Also, you shouldn't need both port triggering and port forwarding for
the same service.  Port forwarding should be sufficient for incoming
traffic.  Port triggering only makes sense of outgoing traffic, which
is already taken care of without any additional redirection.
You also don't need port triggering for Skype.
I suggest you disarm this complex maze for forwarding plus triggering,
and start over with only ftp port forwarding.  When that works, then
put the rest of the junk back *AS NEEDED*.
Jeff Liebermann    jeffl@comix.santa-cruz.ca.us
150 Felker St #D   http://www.LearnByDestroying.com
Santa Cruz CA 95060    AE6KS  831-336-2558
Site Timeline
