Ok recently I installed a BT Home Hub downstairs to save me from having to send a 10m ethernet cable upstairs for xbox live. Upstairs connected via ethernet to my main PC is a Belkin ADSL Modem with wireless G router which I used for my main internet access until I installed the BT Home Hub and they now seem to cancel each other out which means when I'm using the home hub. the Belkin won't connect to the internet. Is there a way where I can use both on the same network? Or perhaps even just use the Belkin is a wired router? Sorry if this makes no sense, I'm not too good with technical jargon.
