uses for Wireless Acess Points ?
Hi I have a couple of wireless AP's and was wondering if there were any other uses for them besides plugging them into switches ?
I have two different internal networks with linksys routers.
Thanks
Jack
Jack Hackett
Well, they're generally too big for paperweights and too light for door stops. You could connect an AP to each of your routers to add wireless capability to each network -- if that's what you want to do.
Neill Massello
They are wireless routers already. They cant be used plugged into the pc's lan card to turn it wireless somehow can it ?
Jack Hackett
Some APs can be used in bridging mode, which is what you're talking about. You would need to read the spec to find out if yours can,.
Mark McIntyre
