I'm looking for a wireless card for my laptop that must be able to connect a antenna to it.
Does any one know of one??
Buffalo has several, this is what I'd get:
"miguel-lopes" hath wroth:
Only one? Sure:
looks good in writing, but they do not post to the uk :(
if you are in the uk
On Mon, 27 Nov 2006 14:39:48 -0000, "miguel-lopes" wrote in :
Buffalo. Highly recommended.
On Mon, 27 Nov 2006 09:10:39 -0800, SMS wrote in :
The normal power card works fine. There's no need for higher power at one end of the connection. That's like shouting across a distance when the person at the other end is speaking back at a normal level.
"John Navas" escreveu na mensagem news: snipped-for-privacy@4ax.com...
But is it compatible with linux?
What is it chipset? I didn't find anything about chipset!
Thanks
Is the other person always speaking at a normal level? Do public access points always transmit at 30 mw, like the typical WiFi adapter?
When we sit on the beach in Mexico, I connect to an access point 2.2 miles away using a 200 mw HWU54D or HWU8DD adapter. Do you suppose the access point is transmitting at 30 mw?
I honestly don't know.
On Tue, 28 Nov 2006 17:51:08 -0000, "miguel-lopes" wrote in :
I don't know.
I don't know.
When you hold things back in your question (Linux), you tend to get not such good answers. ;)
On Tue, 28 Nov 2006 15:53:00 -0500, Dave Rudisill wrote in :
In general, public access points are balanced on transmit and receive to work with typical Wi-Fi clients. So a higher power client card might be able to transmit to an access point farther away, but not able to receive it.
I see. So that's why my Hawking adapters work so well with distant access points. They have good directional antennas for receiving and high transmit power for talking back.
On Wed, 29 Nov 2006 06:43:33 -0500, Dave Rudisill wrote in :
transmitting.
The antenna helps both send and receive. Probably no real need for higher power.
Is anyone using this card with aircrack??
on Windows and Linux??
Thanks
