I have a DWL-122 in the garage, and to get a good signal I made a 20 foot extension from cat5 cable, using 1 pair for power and another pair for data, Anytime I switch on a light or whatever, I lose the connection for a while. Does the extension need to be shielded? Also, after about 20 minutes, the little screen icon in the task bar lights up with one screen lit, and is unresponsive until I unplug and replug the USB connection. Again, is this because of thr unshielded extension? Thanks in advance, Rob
- posted
19 years ago
