I recently installed a Belkin USB wireless network adaptor to my pc and it works fine. The problem is that whenever the connection is enabled, none of my other usb ports work. ie. an error message 'usb device not recognised' is displayed. As soon as I disable the connection from the system tray, and plug in the usb device again, it is recognised as normal. I have windows xp home (SP2). Can anyone help??
- posted
17 years ago
