Hello.
How come every time I unplug and replug D-Link AirPlus DWL-120+ USB wireless network adapter (even on the same USB port), Windows 2000 SP4 (all updates) has to redetect and reinstall drivers? Also, when using its Configuration Utility v3.0.0.1 to connect to an WAP, I get a blue screen with tiacxusb.sys. The only way to fix this is to remove the DWL-120+ USB adapter, remove from device manager, reboot, replug the adapter, redetect, reinstall, reboot, and then I can connect without blue screens.
This is pretty annoying. I bought an USB wireless network adapters to use on multiple computers and old notebooks.
Thank you in advance. :)
