My daughter is trying to set up a wireless connection between her desktop and her daughter's in the next room.
She is using a wireless Netgear Router, Cable, Windows XP, SP2.
Her daughter's computer runs the same software.
When I was at her house and installed the ASUS Adapter LAN PCI WL-138G, IEEE802.11g 54 Mbps, it worked initially and I was able to get on the Internet on her daughter's computer.
I then updated via the Express route Windows XP, restrted and thereafter could not sign on anymore to the Internet. (This page cannot be displayed)
Device Manger shows the card installed, no yellow exclamation mark, and that the device is working properly.
I un-installed the device and re-installed the PCI card with the supplied CD, but it gain would not connect.
What can I advise her to do now?
