I have a NetGear 814V2 Wireless Router hooked up to my Motorola Surfboard Sb5200 connected to Comcast. My one Laptop hooks wirelessly without any problems and I can surf the net, do E-Mail etc. but my other laptop will NOT pull an IP address.
The "problem" laptop sees my Wireless router when I check in "Symbol Mobile Companion" but I cannot get it to pull down an IP address. When I check on the "Attached Devices" page of the Router configuration it doesn't list the "problem" laptop as being connected. I have triple checked that the correct WEP key is entered on the Laptop an also tried it with encryption switched off but still no IP Address!
Any ideas or pointers?
WiFi card is a Symbol Technologies Spectrum 24 802.11b (same as in other Laptop and YES I have switched it out for a "known good")
Router is a NetGear 814V2
O.S. is Windows 98 Laptop not currently firewalled.
