I've got two linksys Wireless G routers networked. The first, a WRT54GS is hooked up to my Toshiba cable modem. The second, a WRT54G I assigned as an access point. It is wired to the network and connected to a PS3 at the other end of house. I was also using it as wireless extender at that end of house, successfully without problems.
When I set up I wasn't using security settings but have recently re-established WPA PSK security on the primary router which means the extender is no longer working as wireless access point with a laptop on which I reset the profile to WPA-PSK. I figured I could wire the extender up to laptop and establish security settings identical to the primary router, but can't figure out how to do this without resetting the extender.
I unplugged the primary router, plugged in the extender to modem and computer and tried to log into it to add wireless security but can't log into the settings to save my neck. I was sure I knew the address, http://192.168.1.2 for example, but nothing works. Am I gonna have to reset this using the original linksys setup disk?
Is there an easy way to do this? Thanks in advance.
