- I have Windows XP SP2
- D-Link wireless router with built in modem dsl-2640b
- Sony Vaio with Intel 3945abg wireless card
- I'm relatively computer savvy
- AT&T is my ISP provider
I can access the internet when hard wired to the router.
Windows IP Configuration
Host Name . . . . . . . . . . . . : jt-thesoftforge Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Broadcast IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connection Physical Address. . . . . . . . . : 00-13-A9-47-40-0D Dhcp Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 76.237.8.247 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 76.237.8.247 DHCP Server . . . . . . . . . . . : 192.168.1.1 DNS Servers . . . . . . . . . . . : 68.94.156.1 69.227.255.30 Lease Obtained. . . . . . . . . . : Thursday, January 31, 2008
21:38:17 Lease Expires . . . . . . . . . . : Thursday, January 31, 2008 21:38:47Ethernet adapter Bluetooth Network Connection:
Media State . . . . . . . . . . . : Media disconnected Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) Physical Address. . . . . . . . . : 00-10-60-D0-0E-E8
Ethernet adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected Description . . . . . . . . . . . : Intel(R) PRO/Wireless
3945ABG Network Connection Physical Address. . . . . . . . . : 00-18-DE-09-C4-D4Please note that the default gateway is not the router. If I disconnect the wired connection and switch to wireless card, I will have internet access for a few minutes before the following settings will be applied to my wireless card:
Media State . . . . . . . . . . . : Media disconnected Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connection Physical Address. . . . . . . . . : 00-13-A9-47-40-0D
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) PRO/Wireless
3945ABG Network Connection Physical Address. . . . . . . . . : 00-18-DE-09-C4-D4 Dhcp Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 192.168.1.2 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.1.1 DHCP Server . . . . . . . . . . . : 192.168.1.1 DNS Servers . . . . . . . . . . . : 128.9.0.107 Lease Obtained. . . . . . . . . . : Thursday, January 31, 2008 21:46:43 Lease Expires . . . . . . . . . . : Thursday, January 31, 2008 21:46:53Everything looks correct except the weird DNS ip address which I have no idea where is coming from.
This network card is able to connect to other wireless routers. The router is not defective as I have replaced it and am still experiencing the same problem. Any attempt to override the automatic settings on the router or wireless card do not result in any success even if settings are identical to wired access which is working.
I have disabled all possible firewalls and anti-virus programs as well as upgrading to the latest driver updates and trying to fix my winsock. I tried connecting two other laptops but no success (both of which happened to be Sony Vaio). I can access the router wirelessly but cannot access the internet nor ping any ip address including DNS with a success (aside from the router).
I have a feeling that this is a hardware issue with my wireless network card which for some reason doesn't like the router. I've posted in other places though with more emphasis on the router rather than the wireless network card. I have been trying to troubleshoot this for many days now and am at the point of giving up and getting a different router/modem, though my curiosity currently keeps me at it.
If anybody else experienced something like that, I'd appreciate any pointers.
