I have been struggling on and off for a year to get this working properly as seen here.
I got it working for about a month or less and then gave up. A few months later I set it up again got it working and then again it stopped working, so I gave up. I have been through this exact process a few times this year. Everything works for about two weeks and then boom my laptop will not connect to either access point or wireless router.
I have a Compaq Presario 2500(2580US) with a BroadCom 802.11 b/g wi-fi card built in. Unfortunately, I do not have any other wi fi devices to test this with.
I just reinstalled the laptop's OS, thinking maybe my wi fi connection issue is due to some junk on my system causing a conflict. That hasnt cleared up the issue.
My first and second attempt at getting this up and running the linksys router I have turned into an access point was over 500 or more from the linksys ROUTER. The access point is now closer about 250 feet away from linksys ROUTER and Im still having the same unable to connect issues.
ATM when I type in http://192.168.1.2 (the address of the access point) or try to ping it I am unable to connect in browser or ping it. Yet the PC that is hard wired from that access point is still connected to the network and I can surf the net with it?
Well i appreciate any comments or suggestions!
Thanks, Chaser
