I'm having a problem with the range of my Wi-Fi network. I'd like to move the wireless access point to a higher spot in the home (a bedrooim), but there's no TV cable jack in that bedroom--however there is a cat-5 wire running up there.
I currently have my Wi-Fi in the far end of the house on the main floor. Ideally, I think the Wi-Fi point should be moved to the upstairs bedroom (where the cat-5 is but no cable outlet).
Is it possible to use the hardwired router as my Internet gateway. Then place the wireless D-link router in the upstairs bedroom which would connect via a LAN port?
-----/internet through cable/---------------[wired router]---------[wireless router]----z-----[wireless clients]
Both routers are D-Link. The wireless is a "B" setup (DI-514)
