I am using two netgear routers (WGR614 and MR814) for the following situation. I have the WGR614 as the 'main' router and the MR814 as an access point. The MR814 is configured with DHCP off and the ip address assigned outside the range of the WGR614's ip range.
This works fine with my current setup which is as follows: Hooked to the WGR614 is
1 wireless computer 1 wired computer 1 xbox with xbox live 1 ethernet cable going to the MR814The MR814 has an external antenna that reaches one other computer in a workroom (the workroom is actually a seperate building) behind the house wirelessly.
My problem is that I have gotten a new notebook computer and am trying to use it in the workroom also. It is showing a strong signal from the MR814, but not an ip address. When I take it into the house, it connects with no problems to the WGR614. What am I missing to get the notebook and desktop in the workroom online at the same time?
I tried turning DHCP on for the MR814, but it kills the computers hooked to the WGR614. Any ideas?
