Two Buffalo routers problems
Hello, i have very big problem. I have two buffalo routers: 'Buffalo Technology - Products - Wireless-A&G MIMO Performance* Broadband Router and Access Point with High Gain Antenna'
'Buffalo Technology - Products - Wireless-G 125* High-Speed Broadband Router and Access Point'
want to set this routers to make wireless network. What i have to do.? Sorry for my not good English :)
ifixas
ifixas hath wroth:
Look in the manuals under WDS (wireless distribution system). It's designed to connect two routers and expand a network. As I recall (not sure) both your routers support WDS, although there are some models that do not.
You can also replace the stock firmware with an alternative:
Jeff Liebermann
