Upon having issues with my Two WAP54G (Which are setup as bridges for each other). I wanted to readup more on this. And found I would post my own topic.
My WAP54G Access Point History... I have successfully configured both AP's to act as a bridge. And Successfully tested them. This is how I have it setup.
AP01 - Bridged AP going to Switch. This one Gives network and Internet access to AP02.
AP02 - Bridged for a VoIP Phone. A VoIP phone is connected to this.
So from the Phone it goes like this:
VoIP --- AP02 ~ ~ ~ AP01 --- Switch --> Network.
I have tested this many of times. My First problem arose when trying to have AP01 goes through a Dark Tinted Window. I soon learned that Tinted Windows do not like 802.11. So I moved AP01 outside. I had a connection, weak as it was it would drop the signal and regain it again, thus dropping any calls being made on the phone. I found the culperit was the electrical boxes next to the AP02. So naturally I moved it away from the electrical. And now, It still drops the connection and I can not figure out why. I believe it is still close enough to each other, for one it is a straight shot with no big obstructions. There is a small obstruction, which is only a few wood frames but this should not cause the loss of conenctivity.
This is where Im stuck. And can not find a solution to this issue. Any one help?
