Having seen several threads about this type of WiFi coverage issue, I was wondering about having 2 AP's at ends of the house to provide better coverage....
If we have 2 AP's with the same SSID, both connected to the same IP segment, and the DHCP coming from one router, then what are the issues involved ??
Not really a roaming issue, but it can be...
SO - we have one AP upstairs in the middle of the upstairs bedroom area, and another down in the family room area. Will you "associate" with the strongest signal ? Is that always true ? In the middle, can you ping-pong between them ?
For the most part - you are either upstairs or downstairs. What happens if you are downstairs, and then walk up to your room to do homework - will you re-associate with the closer & stronger AP ?
Just wondering how this could/would/should work with multiple AP's all on the same channel & SSID ?
