WPA is nothing more than WEP encryption, with a much improved group key exchange mechanism, and 802.1x RADIUS authentication added. If you're just looking at the encrypted data packets floating by, WEP and WPA look exactly the same RC4 cipher stream. When the new an improved
802.11i encryption standard eventually becomes available, the encryption will change to AES which will hopefully be recognizeable by Netstumbler.
