Thanks for reply.
I bought this Access point a week ago
It is a Intel PRO Wireless 2011 LAN Acess Point
Ex owener says he has been us000347144EC3
I was going to telnet to it assuming that is an IP address according to Intel=AEPRO/Wireless 2011 -Access Point Product Reference Guide It says "Section:Gaining Access to the UI The method for establishing access to the UI depends on the connection used. Select the setup that best fits the network environment.
"2.1.1 Using a Telnet session to gain access to the UI requires that a remote station have a TCP/IP stack. The remote station can be on the wired or wireless LAN. To access the AP from the workstation:
1=2E From the DOS prompt Telnet to the AP using its IP address: Telnet xxx.xxx.xxx.xxx
2=2E At the prompt type the password: Intel The password is case-sensitive."
but I think that is shorter than an IP address to be telneted... there is WLAN Utilities in intels website that I have downloaded but WLan Monitor application says 'An Intel(R) PRO/wirless 2011 LAN adaptor not found'
Thanks .
