Router: Netgear BEFW11S4, firmware=1.45.10 (802.11b) Client: 2wire Wireless Ethernet Client (802.11b)
Problem: router is one story above client. Exactly above it, give or take 2 feet. The fastest I can get is 4.3mbps. I've tried Channels
1,3,5,6,9,10,11 and 4.2 steady is the best I can get. According to the 2wire manual it can go up to 22, whereas the ancient BEFW11 can go up to 11. Either way, 4 seems really low. I've tried putting the antennas perpendicular to the other, parallel to each other, even both facing straight up and down, both North-South, both East-West. I've tried putting the boxes parallel to each other, perpendicular to each other, even both sitting up & down. No dice. I can get lower speeds, but 4.2 appears to be it.What should I be trying next? The only wire in the floor (residential house) are the speaker wires in the floor, and I've tried moving a couple feet away from them, no dice.
Any help greatly appreciated.
