Time Warner/Road Runner is offering me a connection to the Internet through an RCA cable modem, Model DCM425:
I need to connect the only Ethernet port from the cable modem to a TP- LINK TL-WR642G router
After noticing some problems I thought the two routers where conflicting, so I changed the internal IP of the TP-LINK to
192.168.2.1, but I cannot still connect to the InternetWhat am I missing?
Could my ISP check that there are connections from other MAC addresses and block them?
What should I do to fix this problem?
Thank you lbrtchx
