trying to add another AP to an existing network
I have a Cisco wireless Aironet 1100 (AP) connected to a Cisco 800 series router which is acting as the gateway.
Im trying to add a 3com officeconnect wireless router as another access point but it doesnt see the Cisco network (can't even ping)
Both the 3com officeconnect wireless router and the Cisco Aironet 1100 acces point are on the same network and channel
I had no problem adding another aironet 1100 AP
Sopwith
Sopwith hath wroth:
Try really hard to find the model number of the 3com. I'm sure it's on the box somewhere.
Set the IP address of the 3com something router to an unused address in the same Class C IP block as the Cisco 800 router (without duplicating any IP's). Do NOT use any IP addresses that are inside the DHCP servers IP address pool. Do the config from a directly connected PC.
Make sure that the DHCP server in the 3com whatever is disabled.
If you're running a DHCP client on the unspecified model 3com OfficeConnect, verify that it is getting and IP address by looking at the DHCP address table (or ARP table) in the Cisco 800 router.
Since you're apparently using a 3com something router as an access point, do not plug anything into the WAN (internet) port. Connect the CAT5 cable that eventually goes to the Cisco 800 to one of the LAN ports on the 3com something. Check the lights to make sure the ethernet cable is working. If no lights, then you'll need an ethernet crossover cable or adapter.
Jeff Liebermann
