I'm a relative neophyte and haven't been able to find specific instruction on how to accomplish my task with my wireless network. I bought a Belkin WAP to connect to my wired ActionTec gateway which is what Qwest gave me when I picked up their DSL service. Everything's running fine, and then my neighbor decides to ask me if we could get in a sharing arrangement. Problem is, he can only get a low signal trying to see mine. So, I had him buy another Belkin WAP. The instructions state you can connect router to WAP, but not WAP to WAP. However, on my WAP, it allows me to specify APs that can connect. Long story short, he can see his Access Point (which has a different SSID) and everything else is the same (Channel ID, WEP settings). However, he's not able to get to the internet (his WAP is not hooked to my router). Is this not possible to do? Is the only way to accomplish this through an antenna booster/etc. for my current WAP?
Thanks,
Matt
