After seeing many recommendations here for the HomePlug solution to link two machines, I got a pair of Netgear XE103 boxes to see if they would work better than my WAP54G/WPC54G wireless link.
So I unplugged the cat5 cable that goes to the WAP54G on my router (hooked to my desktop WinXP) and plugged one of the XE103 boxes (which is plugged into a nearby electrical outlet).
On the laptop that used to be the wireless client machine I umplugged the WPC54G (PCCard), rebooted the machine and plugged in the other XE103, like the little booklet said -- and that's all the booklet said.
Amazingly, the MS network works and I can look at the hard drives from either machine, etc. But the laptop can't find the net with any browser, ping doesn't work.
I presume the wireless setup I had is the problem. Since I've never found any trace of software or anything else involving the laptop wireless thing, I have no idea where to start. Here's the IPConfig /all: Windows IP Configuration
Host Name . . . . . . . . . . . . : Toshiba_Laptop Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : houston.rr.com
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : houston.rr.com Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connect on Physical Address. . . . . . . . . : 00-08-0D-9F-89-C3 Dhcp Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 192.168.15.101 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.15.1 DHCP Server . . . . . . . . . . . : 192.168.15.1 DNS Servers . . . . . . . . . . . : 192.168.1.1 192.168.1.2 Lease Obtained. . . . . . . . . . : 2007, April 21
18:44:56 Lease Expires . . . . . . . . . . : 2007, April 22 18:44:56Ethernet adapter {E2D47AA7-8E9A-4E5C-8E90-277D10DEB84E}:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Nortel IPSECSHM Adapter - Packet Scheduler Miniport Physical Address. . . . . . . . . : 44-45-53-54-42-00 Dhcp Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 0.0.0.0 Subnet Mask . . . . . . . . . . . : 0.0.0.0 Default Gateway . . . . . . . . . :
I appreciate you readers taking the time -- any hints of what to do next would be appreciated. Meanwhile, I'm going to see if my wireless network still works.
