DSL Details Modem Type Built in modem - ADSL/VDSL
DSL Line Line 1 (inner pair) Down Up User Rate 13215 kbs 1534 kbs Max User Rate 31920 kbs 8909 kbs Noise Margin 21.8 dB 25.9 dB Attenuation 20.8 dB 19.7 dB Output Power 13.1 dBm 7.5 dBm
Protocol G.993.2_8d Channel Interleaved DSLAM Vendor Information Country {46336} Vendor {BDCM} Specific {41971 } Rate Cap 31731 kbs Attenuation @ 300kHz 11.7 dB VCXO Frequency Offset 21.0 ppm Ok Excessive Impulse Noise 1 Interleaved mode recommended
What is Max User Rate vs. User Rate? And how come when I play with any of these numbers (I'm probably not doing it right) I don't come out any of the published AT&T speed tiers (which start at 6Gb and are in 6Gb increments from there upwards).
A speed test shows I'm getting about 8Gb up.
TIA,
-sw
