What methods are usually used for throttling up/download speeds of users? Is this generally done with a software app and at what level? Just wondering.
- posted
13 years ago
Software:
For VoIP:
How it's done in a small wireless router:
What problem are you trying to solve and what equipment/OS/software do you have to work with?
Jeff Liebermann wrote in news: snipped-for-privacy@4ax.com:
speeds
I was just wondering if the open (public?) AP I am using is throttling me or just too far away. Probably throttling since upload speeds much greater than down. Wondering how it's done, prolly just need to buy a better antenna. Thanks.
Meanwhile, at the alt.internet.wireless Job Justification Hearings, hurdygurdy chose the tried and tested strategy of:
Wireless speeds drop off with distance so if you're far enough away it might not be deliberate throttling [although it wouldn't be asymmetrical].
