Things learned about Ubiquiti PoE adapters and devices
Threaded View
I posted this a few weeks back to the AgTalk forum.  I thought some might
find my tale interesting.
Back in September 2009 I set up a 1.5 mile link between farmsteads using
a pair of Ubiquiti NanoStation 5 Loco units (5 GHz WiFi--802.11a band).
These proved very reliable through storms and power outages over the
years until June 30, 2018 when the AP unit at this farmstead went dead
almost with no reason, i.e. there had not been a recent nearby lightning
strike, though a squall line had moved through a few hours before with
some hail. Efforts to access the unit were unsuccessful that evening. The
decision was made to climb the tower and replace the unit the next day
which I did. The unit I replaced it with was in service on this farmstead
for a short link and could be borrowed (the link was down anyway with the
AP down). The replacement went smoothly and the replacement unit operated
as the AP without issue. The old AP was reconfigured and put back in
service for the link where the borrowed unit came from.
All was well until the afternoon of December 28, 2018 when the AP went
down. I was able to access it on its factory default address and found
that all settings had been reset to factory defaults. I uploaded the
previously saved configuration and the unit ran normally for a couple of
hours and then quit again. Efforts to access it were unsuccessful. The
next morning, Dec 29, a Saturday, I was able to access it at the factory
default address and rather than just upload the configuration again, I
opted to update it to the latest firmware for the older NS5L which is
AirOS 4.04. All went well for two days before it failed again and this
time all efforts to access it over the network link failed.
After the failure in June I had ordered a pair of 5 GHz panel antennas
with the intent of eventually replacing the NS5L at each end with Ubiquiti
Bullet 5 units so the radio hardware could be accessed from ground level.
I had failed to order the coaxial cable for this end, however. Rather
than being able to climb the tower immediately I awaited the arrival of
50 feet of LMR-400 cable terminated with N male connectors along with a
PolyPhaser lightning arrestor, both ordered from Amazon on New Years Day.
Both arrived on Saturday January 5, 2019 which was ideal since there was
barely any wind and the high temperature hit 62F! The climb was completed
with the NS5L removed and the panel antenna and coaxial cable installed
with a single climb to the top.
At the bottom I connected the Bullet and it immediately went into
firmware upload mode which caused a reset of the configuration to factory
defaults. I went back and forth on this several times until some Web
searching revealed that Ubiquiti incorporated a remote reset capability
into their units but never documented it until the M units were released
when, with AirOS 5, a setting was available to disable the remote reset.
From what I found if voltage or ground (I don't recall which) is present
on the data lines (pins 1,2,3 or 6 on the 8P8C connector), the unit will
go into remote firmware upload mode. I swapped out the PoE injector with
a known good one and the problem persisted which pointed to the cabling
between the house and the Bullet.
The cable had been in place since the initial installation in 2009 and
was run of the mill UTP (Unshielded Twisted Pair) Cat 5 cable with a
black outer jacket. In the process of troubleshooting the Bullet I cut
off the section that ran up the tower and terminated it with a new 8P8C
connector that did not resolve the issue. As i have a box of Ubiquiti
Tough Cable which is STP (Shielded Twisted Pair) Cat 5e the only choice
was to replace the end between the PoE and the Bullet on Sunday which I
did. Service was restored and has been solid since. I also replaced the
aging Cat 5 UTP going to the WISP's Nanobeam that had supported three
generations of their equipment and had a poor splice in it. A nice result
of doing that for both links was that noise to my amateur radio station
was greatly reduced and Ubiquiti equipment resets from my transmissions
were also eliminated. A win win!
Thinking about it after things were working, even had I known about the
remote firmware upload capability, it would not have mattered as the
failure state was putting the unit into remote firmware upload
continuously. I had tried the TFTP method to upload new firmware while
the NS5L was in failure mode and could not successfully upload any
firmware. Perhaps the older units did not fully implement the protocol. I
later removed all the old cabling and didn't find any obvious damage.
Perhaps the cabling just became contaminated over time. No water seeped
out that I could tell.
To garner sparing I purchased 2 NOS Bullet M5 units and ordered what I
thought were the correct PoE adapters for them. Turns out I missed the
section on the PoE datasheet where it was shown that the ones I ordered
put power on all four pairs while the units only accept power on 2 pairs--
pins 4,5,7 & 8. At least I was able to order the correct PoE adapters and
return the incorrect ones for a refund (minus the shipping charge to send
them back, a bit of stupid tax, I guess). Lesson learned, be careful to
be sure the PoE and the powered device match though this information
requires some careful reading to get right.
A bit more work remains as I plan to dig in a conduit to run the network
cabling in between the tower and the entry point into the basement. That
will wait until warmer weather!
- Nate
"The optimist proclaims that we live in the best of all
possible worlds.  The pessimist fears this is true."
Web: http://www.n0nb.us GPG key: D55A8819  GitHub: N0NB
Re: Things learned about Ubiquiti PoE adapters and devices
On 2/17/2019 11:58 AM, Nate Bargmann wrote:
Sounds like good solid troubleshoot skills win again... ;)
I wish!
It was more like, "Welp, this is the last thing to try..."
- Nate
Ubiquiti supports passive POE which should NOT send any voltage down any
pairs until the POE brick determines the device attached with accept it.
Generally when a Ubiquiti device starts resetting to defaults it's
because the voltage pairs are shorting together.. In fact that's how the
reset button works... Short the pairs for a few seconds (15-20) and the
device resets to factory defaults..
In the field a crushed or cut cable can exhibit this problem..
The erroneously purchased four-pair PoE bricks did just that, and did not
supply power to the older device.  It just went to flashing its LED.
Posting a question on the Ubiquiti forum gave me the answer.
I didn't find any physical damage where I looked but once the decision
was made to replace it I didn't inspect it closely at all.  At least if
presented with a similar situation in the future I'll be better prepared.
- Nate
Site Timeline
