the lesser spotted Gigabit Ethernet port ? - Page 2
Threaded View
Re: the lesser spotted Gigabit Ethernet port ?
On 1/28/19 3:26 AM, NY wrote:
I'd say you're absolutely correct.  Still, that gives you 500mbps
transfer speed. I'm not really claiming it will even do that, I'm sure
there's processor overhead and whatnot, but I suspect that one could do
some number > than 100 mbps.
I can believe that.  So if we assume these scale linearly, then a router
advertising 1000 mbps should, theoretically, be able to transfer from pc
to pc at 200 mbps which would be double the ethernet port.
Of that I have no doubt. There are many factors that affect wireless
transmissions, but nevertheless my only point was that a router with a
100 mbps port can still transfer data faster than 100mbps. Yeah, it
would make a whole hell of a lot more sense to have a 1000mbps ethernet
port, but it's not an isolated case.
Ubiquiti pulled that crap with nearly every M series device they ever
sold (with a few exceptions).  Using a 40MHz signal, one could get a
300mbps connection, the system was full duplex which gives you a 150
mbps connection in both directions.  But since the radios had to connect
to the rest of the network with the ethernet port, the 100mbps port was
a significant bottleneck.
Agreed
I think you mean OP..? I'm certainly not a doctor..!
Ria in Aberdeen
[Send address is invalid, use sipsoup at gmail dot com to reply direct]
GP = grandparent.. the poster above the poster being replied to.  I
wasn't referencing the OP.
On Wed, 16 Jan 2019 23:57:41 +0000, MissRiaElaine
That would be useless.
Being without ADSL would be OK though.
Site Timeline
