Dear Group
Can anyone tell me whether this device supports telnet access? Called the support line and they escalated my call. Typical.
What port shall I use? 23 doesn't work. 80 just hangs the connection without the password prompt coming up.
Device details: Belkin Product Part Code: F5D8230-4 Product Version Number (If Applicable): 2000UK Serial Number (If Applicable): BEL25PVR
Enabled Remote assistance for any IP but didn't change the port from 80 to 23 as otherwise the web based interface won't come up. Note that I try to administer the router from within a private LAN. Doesn't act as a DHCP. Another router does this but I'm connecting to the device directly over wireless. Any firewall settings?
'If it doesn't do telnet I may just put it in the bin.'
