techra 4m wireless drops consistently
I just recently purchased the all new Toshiba Tecra 4M with integrated wireless G. I've found that at both home and work, the wireless drops every once in a while but more frequently with large amounts of data transfer, almost as if resetting after a certain amount of traffic. At home, I have to 'repair' the connection to reconnect. As soon as I do so, I reconnect with no problem but it's annoying to have to do so. At work, it will seemingly reconnect on it's own, but there is still the interuption. The only difference between the two networks is that at home I've only allowed specific mac addresses. How on earth can I figure out why my wireless is dropping every so often?
slashdrew
Could be a whole lotta things. Try a couple simple things first.
  1. Set your laptop to only connect to preferred networks.
  1. Trying changing channels on the router.
Worked for me after a neighbor installed a home network with the same router on the same channel as my home netwotk.
Billy Bob
And don't waste your time "hiding" the SSID - that way others can easily see your channel number and avoid it.
Doz
Would make sense, except I have the same problem both at work and at home. Can't hurt though.
slashdrew
