I am interested in a wireless router to share internet between 2 computers but have never used a router before.
My one concern is that I have two ADSL accounts with two ISPs, and need to be able to switch easily on the fly between one login and the other (just different login id/pass over same DSL phone line). Currently to change logins, I just disconnect the one then click the other network connection icon shortcut to connect.
How would I do this with a router? Doesn't a router login using its own internal preconfigured software and settings? If so, is there a way to enter two logins and switch between them (and are some routers easier than others?)?
