How does Windows 10 handle manual & automatic switching between Internet WiFi & Ethernet connections?
Does it automatically switch based on the best signal strength? Or does it automatically switch based on some test speed?
If I want to manually change from one connection to the other, how do I do that?
# I have a desktop with no WiFi card. # On a USB port, I have a $25 AC1200 TP Link "T4U" wifi dongle (FCCID TE7T4U, IC 8853A-T4U)
My two questions are
- How does Windows automatically decide which to use?
- How do I manually switch from one to the other?
