Hi
Forgive the phrasing, wireless networking is something of a new thing for me...
I've been asked to set up a wirless network with two distinct levels of access.
The first will be for visitors. They will be asked to log in using a key we designate and upon access, will only have access to the internet.
The second will be for staff. They will connect, also via a security key, and have access to all objects on the domain (printers, servers etc.)
Can I get some suggestions regarding...
a) number of access points and/or routers that would be needed (average number of guest connections would be 10, average number of user connections would be 50). My preference would be to have a little in the way of gear as possible b) recommendations for configuration (sub-nets tied to specific switches, NAT or something else) c) recommendations for hardware (CISCO, 3COM...bridge vs router etc.)
Any and all advice appreciated!
Thanks in advance
