Hi Folks,
I have got a problem accessing the setup pages of my modem from behind my router. My modem is in bridge mode. I could access the setup pages when it was in half bridge ok.
Anyway, my setup looks like this:
ISP-------Modem--------Router--------------PC ISP---192.168.0.1---192.168.1.1---192.168.1.100
Again the modem is in bridge mode with DHCP turned on. Its a Dlink
302G.The router does the login via PPPoE and has DHCP turned on. Its a Linksys WRT54G running DD-WRT v24.
I tried setting up a static route with:
Target IP Net: 192.168.0.1 Subnet Mask: 255.255.255.0 Gateway: 0.0.0.0 Interface: WAN
My modem is plugged into the WAN port.
If I plug my modem into my PC directly I can see that the gateway is indeed 192.168.0.1.
Why is this not working????
I am not sure that there is much I can do to try and isolate where its failing?
Any help or suggestion appreciate.
-Al
