Hi there, i'm struggling with my wireless settings. I've just bought a ps3 and want to get it online. I have broadband but the dial up type rather than an always on connection. the modem i have is the standard speedtouch which i can't connect to my router.
I had a similar setup in my old flat where my housemate connected to the net through his laptop which had the modem, and i connected to him wirelessly.
Basically my pc has the modem in the current case and i need to share the connection wirelessly with the ps3. i've got it working but i'm sure there myust be a better method as it makes the connecon and the pc very unstable. I basically have the modem in a usb port, i've hooked an ethernet cable up from the pc to the router's wan socket. i've then got a bridge between the wireless and Lan connections.
Is there a more straightforward method i could use without purchasing an adsl modem and router package?
