Speed problems with Linksys WAP
Hello all,
I have a Linksys WAP54G and a couple Acer notebooks. My connection speed varies wildly for no reason I can discern.
When I first turn on my notebooks (or "Repair" the wireless connection), I get:
Speed: 54.0 Mbps Signal strength: Excellent
This will last for a few minutes and then it switches to:
Speed: 24.0 Mbps Signal strength: Excellent
But when it does switch to 24.0 Mbps, it is not just under half as fast as when it was at 54.0 Mbps. It's closer to 1/10 the speed.
The signal strength never changes from excellent. And the WAP is no more than 20 feet away from the notebooks (although it is on the other side of a normal house interior wall). I used to have an Acer notebook (made 3 years ago) that always maintained a solid 54.0 Mbps connection. But for some reason these two new notebooks spend most of their time at 24.0 Mbps. They'll sit there for a few minutes, go back to 54.0 for a minute, and then back to 24.0 for a few minutes.
This happens on both laptops, and it isn't affected by whether or not the other notebook is on.
Anyway, I was just wondering if there are some kind of wireless settings I should be examining. And why is 24.0 Mbps a tenth the speed of 54.0 Mbps? And why, if the problem is simply reception, is it that my signal strength always reads as Excellent?
Thanks in advance.
James
James Martin
Sounds like interference... Mine started doing that (slowing down) and after a few months, I finally narrowed it down to a hi intensity lights transformer. If you want a quick test, I just turned off all the breakers for the whole house ( cept one, I plugged the wap into that, ran the laptops on batteries) just to see if that changed/narrowed it down, when it did, I just started turning on one breaker at a time until it started screwing up again.
Peter Pan
