Instead of feedback, would you settle for some calculations? The missing factor is how dense and thick are the trees. If you had bothered to describe the obstructions better, it might be possible to grind the numbers with more accuracy.
What I know (or guess) is: Two 24dBi antennas. Two 15dBi transmitters mounted on or near the antennas. cable modem which implies at least 6Mbits/sec required thruput. 1/3 of a mile end to end. Commodity hardware. Undefined amount of foliage Undefined line of sight and fresnel zone clearance.
See the FAQ at:
for how to do a microwave link calculation.
TX power = +15dBm TX coax loss = 1dB TX ant gain = +24dBi Distance = 0.333 miles RX ant gain = +24dBi RX coax loss = 1dB RX sens = -75dBm (for 36Mbits/sec connection) Fade margin = unknown
The system requires a 20dB fade margin (SOM) in order to be reliable. See the table for reliability and fade margin at:
20dB is considered a good MINIMUM fade margin.Usually, there aren't any trees in the way, so there's no need to throw that into the calculations. The easy way is to just tack it onto the required fade margin.
My guess(tm) is that a single medium size tree, of medium density, and of the broadleaf variety, is good for about 15dB of loss. If you're going through two trees, it's 30dB. If you're going through a thick redwood forest (like my house) forget it. If you're going through a thick tree trunk, also forget it. I'll be optimistic and use 15dB loss.
Plugging into:
I get a fade margin of 41.3dB. Subtracting off the 20dB required fade margin, you have 21.3dB left for foliage attenuation (and any other losses I didn't include). That's not too horrible and sufficient to drill your way through one medium size, medium density, tree. Any more and forget it.
Note that this assumes that you have nothing inside the Fresnel Zone. At 0.33333 miles, you need at midpoint about 10ft radius around the line of sight of clearance. Obviously, the trees are in the way. However, so might the ground. The access point on a "hill" is ideal but if you have some other junk along the line of sight, it might add additional losses.
