I've just bought a Buffalo Air Station Ethernet Converter (WLI-TX4-G54HP) to use with my fairly new Slingbox. I have tried everything, but the connection between my router (Netgear WPN824) and the air station is flaky when near to each other, but non existent when more than 10 feet away from each other. I have been prancing around the sitting room with the Buffalo in one hend seeing if I can get any signal at all from the Netgear router which sits just above the lounge in the spare room/study. I'm now considering a high gain aerial (WLE-HG-NDR), but before I throw even more good money down the drain, should I bother, and will I get a connection?
I didn't think I would have any problem with signal strength, as I already use two laptops around the house without any problems, although the strength of the signal in the lounge goes from good to very low depending on where I'm sitting with the laptop.
I bought the Buffalo because of recommendations from loads of places on the web saying it is the best one. I have spent a day and a half trying to configure the bloody thing, trying to use WEP but then discovering that doesn't work so have had to change my network to WPA-PSK. Not a problem, because it is more secure, however, it now means my wireless IP camera doesn't work because it's only got WEP (more frustration!!).
