SMC wireless modem/router needs restarting ever hour or so
I have a wireless internet set up in my home . I Have just decided to extend the range by simply running a LAN cable from the existing wireless router to another floor and connecting another wireless modem/router to it. I have set up the new router to be within the existing network range
192.168.0.xx and use DHCP to serve the users.There are about 3 or 4 computers connecting.It all works for an hour or so and then the new router hangs. By hang, I mean the new router cannot be seen by the computers and it must be rebooted/restarted to work again. The router is a SMCWBR14T. I note that it is fairly hot but certainly not too hot to touch or hold comfortably. What could be causing this ?
-keevill-
On Mon, 26 Mar 2007 07:52:42 +0700, "-keevill-" wrote in :
Wireless access point. Or wireless router configured as a wireless access point (see How To below). Not a wireless modem.
Bad idea. Have only one DHCP server, or make sure multiple servers have different ranges.
Misconfiguration.
John Navas
Wireless router configured as a wireless access point.
1 is set up to dole out IP addresses in the 192.168.0.20-49 range and the other in the 192.168.0.50-65 range
what are of the configuration should I be checking then? Could it not just be a faulty piece of equipment??
-keevill-
