Not sure if this is the right forum/newsgroup as I don't think the issue is with the wireless element!
BT line TOK, so BT will not take a fault?.......using a Netgear DG834GT,
Connection staus
ADSL Link Downstream / Upstream Connection Speed 1856 kbps / 416 kbps Line Attenuation 59.0 db 31.5 db Noise Margin 12.4 db 7.0 db
Usually the downstream is 3+mb
Heres the strange thing though... the telephone line for voice is extremely faint. All wiring in the house checked out...OK
If I unplug the router the telephone line eventually returns to normal after a couple of hours.
