My old super-reliable Linksys BEFW11S4 died on me recently. This 'B' wireless router was working perfect for 4-5 months after I updated the firmware to fix a DHCP problem. About 2 weeks ago the wireless quit working on it, so I figured I would go out and buy a 'G' router. I purchased the Linksys WRT54G and my VPN (and network in general) would not stay connected for more than 30-60 minutes. My old 'B' router used to stay connected to my VPN for up to the 18 hour max (set by my company). I tried updating the firmware on the WRT54G, but it did not help. I took the router back and got the Netgear WGR614, and the same thing is happening. My wireless laptop network keeps disconnecting after 1-2 hours. What the hell is going on? Does the 'G' network have some type of inactivity time-out? Also, the range on my Netgear won't reach my deck outside (the Linksys routers did not have this problem). As much as I don't want to buy a Belkin, I may just have to try that. Any others having a similar problem or resolution/suggestion? I may also buy another Linksys and use third-party firmware. Also, I was using WEP security on my 'B' router, and tried no security, WEP and WPA on the new G Linksys and that did not matter. Thanks for any advice.
- posted
17 years ago
