I was wondering if there was any thought to shielding and/or guiding the wireless signal, to 'aim' it so to speak and thereby preventing (at least the majority) of it from broadcasting all over the place.
Of course the main line of security is encryption and password protection. But I was also wondering about setting up something I'll call 'shadow' to cut out whole regions that don't need any coverage in.
An example; a home user places a wireless router in the corner of the room near the phone jack. Since the wireless node is sitting up against two walls why not block/reflect the signals coming from it back towards the rest of the property, perhaps in some way gaining the benefit of increasing security against roving folks who might seek to tap your signal.
Besides the seemingly paranoid aspect there might also be some improved reception to be had from concentrating, focusing if you will a directed signal _towards_ the intended recipient in the dwelling. Even if it's intended for a roving laptop the coverage doesn't need to be a full 360 degree bubble around the wireless hub.
Perhaps it might be something simple as sitting a stainless steel bowl or mirror behind the hub, perhaps it might really require some engineering.
Just a thought tossed out to see what discussion might come from it.
TBerk
