I am in the process of setting up a small wireless network for my home. I have a computer based on the Asus P5AD2-E Premium motherboard with built-in 802.11 G wireless capabilities. I want to use a Linksys WRT54G router that I have and an HP 3310 printer with built-in wireless. I know from researching the Linksys product and the HP printer that they have the same Secure Easy setup options. Where I am not sure of is the following:
1) Will the Linksys router find and/or recognize my Asus mb with built-in 802.11 G?.2) Asus uses their own configuration wizard for wireless setup - is it compatible with Secure Easy setup?.
3) Does the built-in mb wifi support WPA or WPA2 security?.4) How do you setup the Linksys router for wireless usage without setting it up for broadband usage?. ( DSL/Cable unavailable in my area. Use 56K dialup for internet access)
5) Does the Linksys router have a power saving mode?. It and the HP printer will be on an UPS for protection.I appreciate any and all assistance provided in resolving these questions.
Thank You,
Terry D.
