I am setting up a two radio repeater for a distant client to our system.
I have had a router at the distant site acting as an ethernet bridge for some time, so that setup is working fine.
But now they want wifi there, so I'm adding a 3rd. device to the chain (stock WRT54G v4) to act as a local AP. Should be easy as pie to tack an AP on the end of the chain, but what I thought was the obvious setup did not work, i.e., could not ping the ethernet bridge I was cabled to.
I'm a little rusty at the moment, so I thought it might be quickest to just ask for setup comments. I have not seen much online about this setup.
Existing setup:
#0 Hughes Modem with DHCP
cabled to WAN port of:
#1 Router/AP = (Buffalo HP DD-WRT) 192.168.1.1 Gateway, DHCP on WPA
communcates with:
#2 Client Ethernet Adapter - (Linksys WRT54G v4 DD-WRT) 192.168.1.2 DHCP off Ethernet out from LAN port
cabled to WAN(??) port of :
#3 AP (Linksys WRT54G v4 stock firmware)
Question is setup for #3 - the AP
1) Should I go into the WAN or LAN for the AP?2) DHCP on the AP? on or off ?
3) Local IP? I picked 192.168.1.34) Should I give it a WAN IP or automatic?
5) Gateway mode or router mode?6) what else? oh yes, firewall off, right? forgot that yesterday
7) Am I trying to do something that linksys fw won't do? Seems like it should, but I'll flash it with DD-WRT if needed.I started with a reset obviously, and security off. I have no issue connecting the bridge, that has been working for some time. It's just getting the AP to work at the end of the chain. I suppose it would be best if #1, the DHCP router could hand out addys, but it's not critical.
Thanks, Steve
