Hi all,
Can't seem to get this right here. I just got my new laptop (Dell Inspiron 2200) and D-Link Router (DI-624). I believe I have done everything correct as far as I can tell, buit can't seem to get this to work. I went throught the setup program installed the router. Laptop will connect to router it seems, tells me I have a signal and good connectivity, but I can't get onto the net from the laptop. I can get on from the server PC connected to the router. I have tried tinkering around with the IP addresses on the laptop, but to no avail. I seem to be missing something.. Do I need to set a special IP address on the server PC? And of so, where? Also, what should the IP address be on the laptop I am using to connect, and where can I set that? I think I am missing a small piece here. I'm a little green here so I may actually be missing a bigger part than I think.
Thanks to anyone who can help!!
J
