Hi all!
I've been using since last year a wireless router Netgear WGT 624 with an ADSL modem Netgear 632. My Lan is made with 2 PCs. I had some trouble configuring it some time ago but after that everything worked fine with an excellent connection.
Now I've been thinking of putting up a web server at home using the sites that let to use dynamic DNS.
I was trying to test my configuration to see if it was working fine before registering to one of these services. I installed Tomcat on my main PC. Locally I can see it. Then I set a port forwarding on the router (624) for HTTP pointing it to the PC where Tomcat is installed and running. When I try to call from a web browser the dynamic IP address that my ISP is giving me in that moment, I see the admin page of the modem (632). It is like the router forwarding isn't working at all and the modem is answering to that request.
These are the router and modem configuration:
Netgear ADSL Modem DG632
------------------------ Encapsulation PPPoE DNS Servers Primary 193.70.192.25 DNS Servers Primary 193.70.152.25 Multiplexing Method LLC-BASED VPI 8 VCI 35 Connect Automatically, as required TRUE Disable Port Scan and DOS Protection FALSE Default DMZ Server FALSE Respond to Ping on Internet WAN Port FALSE MTU Size 1492 IP Address 192.168.1.1 IP Subnet Mask 255.255.255.0 RIP Direction None RIP Version RIP-2M Use Router as DHCP Server FALSE Device Mode DG632(Router)
Netgear WGT624
-------------- Use Static IP Address IP Address 192.168.1.2 IP Subnet Mask 255.255.255.0 Gateway IP Address 192.168.1.1 Use these DNS Servers TRUE Primary DNS Servers 192.168.1.1 Enable Wireless Router Radio TRUE Enable SSID Broadcast TRUE Fragmentation Threshold 2346 CTS/RTS Threshold 2346 Preamble Mode AUTOMATIC Port Forwarding FTP Port 21 - 21 192.168.0.2 HTTP Port 80 - 80 192.168.0.2 Connect Automatically as Required TRUE Disable SPI Firewall FALSE Default DMZ Server FALSE Respond to Ping on Internet Port TRUE MTU Size 1500 LAN IP SETUP IP Address 192.168.0.1 IP Subnet Mask 255.255.255.0 RTP Direction None RIP Version DISABLED USE Router as DHCP Server Starting IP address 192.168.0.2 Ending IP Address 192.168.0.25
What I'm doing wrong? What should I do to make it working? Thanks a lot in advance!!! I'm getting made trying to configure it up.
mario
