Trying to set this up - but on the edge of my understanding ....
Installed simpleMonitor - and can connect to SB and set setings etc
Tested and in AdHoc mode can connect a wireless laptop to a PC with the airbridge plugged in direct - so assume all is physically working. Laptop can ping the PC - but not the SB ?
In Infrastructure mode I can associate with a wireless AP (acually a wireless router which has internet connection)
But whatever I try I can't get the PC to access the internet through the router. All are static IP addresses - I can ping the SB but not the router - but I'm not entirely sure how this is supposed to work - is it a sort of pass through ?
192.168.1.15 (ClientPC) to 192.168.1.22 (SB) to 192.168.1.1 (ADSL wireless AP)Have I missed something obvious in the setup here - or is it possible that my wireless AP / Router (Dlink G604T) won't work like this for some reason.
Tried DHCP mode - but this didn't seem to get anywhere - even though ADSL wireless AP is a DHCP server.
Is there some security issue I'm missing - I've set the WEP on the SB unit so that it can associate with the AP - and thought that was all I had to do
Any ideas ? Thanks James
