I am having a problem with my signal dropping to zero then re-aquiring network address every 5 or so minutes.
Now i am currently using the USB 362 Senao adapter and if i were to show the signal strength using the Senao utility it says its 30db strong and shows ALL green (Excellent) strength.
If i were to view the signal using the windows utility it only shows TWO bars which is very minimal.
Which one is best to use and what could be the cause for the random disconnections?
Please note i am connecting the USB adapter to an LMR400 cable then to a 24dbi grid antenna.
Thanks
