OK. So you're connected to a wireless network.
How can you find out what other hosts are on the network? Do you need to be the same workgroup as them?
Whether you have only a wireless network or the wireless is part of a wired LAN, it makes no difference. Connecting to shares is the same over wireless as it is over wired.
