I have wpa security enabled with a 64 character random password. I have dhcp turned off, with static ips. I don't broadcast my ssid, and only turn wireless on sporadically. It's definitely not on 24/7. My security log every once in a while shows a wan dhcp client connected that I don't recognize. It will show Fri Feb 10 12:45:55 2006 -WAN DHCP Client Connected IP 192.168.100.11 Fri Feb 10 12:46:03 2006 -WAN DHCP Client Connected IP 192.168.100.11 Fri Feb 10 12:46:06 2006 -WAN DHCP Client Connected IP 192.168.100.11 Fri Feb 10 12:46:10 2006 -WAN DHCP Client Connected IP 192.168.100.11 Fri Feb 10 12:46:13 2006 -WAN DHCP Client Connected IP 192.168.100.11 Fri Feb 10 12:46:16 2006 -WAN DHCP Client Connected IP 192.168.100.11 Fri Feb 10 12:46:19 2006 -WAN DHCP Client Connected IP 192.168.100.11 Fri Feb 10 12:46:23 2006 -WAN DHCP Client Connected IP 70.XXX..XX.XX
With the final entry being my external ip address used by cox cable. The ip address, 192.168.100.11 is not one of mine, nor is it in my same range of ip addresses that I chose. Where does this ip address come from?
Thanks for any help,
Lisa
